tranny info needed
im swapin out my tranny and putting a 5 spd in now my trannys from a 89 civic 1.5 its a 5 spd,im putting it into a 92 civic 1.5 which originally was auto will it bolt up?would i need a 92 clutch or do i need to stay with a 89 either ways alright for me,the 89s clutch is cheaper,any infos usefull,
thanks Will
thanks Will
ORIGINAL: bad4yourdaughter
what if i used the 89s clutch cable and setup???will the axles line up?will i need any diferent mounts?what shift linkage will i need???
i want to stuff my 89 tranny with a cable clutch in to the 92 that has a auto in it right now, will the mounts on the 89 tranny line up with the 92 mounts???
ORIGINAL: HARI.
that won't work for your car. 89 civic tranny is a cable tranny and your 92 civic has lines for the hydraulic tranny to engage and disengage the clutch
ORIGINAL: HARI.
the 92 has no clutch lines because it's an automatic tranny, and that's what your car came with.
your shift linkage will work and all the other stuff from the 89 but bolting it up to your 92, i'm not sure. you will probably have to get a 92 civic tranny mounts, but like i said i'm not sure.
Cwality Civic
Dec 13, 2004 06:01 PM
