Why a d15b jdm ovr a d16a9?
I'm not very familiar with the A9, but I'd put my money on it for all out performance. It's head design will probably out perform SOHC VTEC heads for several reasons. 1) DOHC heads generally flow better. 2) Non-VTEC heads out perform VTEC heads within their desired powerband, without giving up much below the powerband either from what I've seen.
Onthe street you may prefer SOHC VTEC though. It's mild lower rpm cam profile allows for a lower idle,morepower below 3k-4k rpm generally, and better gas milage. The D15B also has a shorter stroke, it should be mentioned, which does help it produce power at higher rpms than similar SOHC VTEC D16s. I wouldn't know how it compares to DOHC Non-VTEC in that regard though; the reasons above still may give it the edge.
Depends on what you need it for. The A9 will also cost a bit more to mod, as it's aftermarket isn't as developed, an extra camshaft/cam gearwill need to be purchased, and it's rod specs are a little bit different from SOHC D16s, so rod manufacturers may charge a bit more for them.
D16A9
Found in:
1988-1991 Civic/CRX/Concerto (UK/Europe)
1989-1996 Rover 216/416 GTI (UK/Europe)
1992-1995 Civic Si (Peruvian version)
1992-1995 Civic GTi
Displacement : 1590 cm3
Bore and Stroke : 75 mm X 90 mm
Compression : 9.5:1
Power : 130 hp @ 6800 rpm & 108 ft·lbf @ 5700 rpm
Valvetrain : DOHC
Fuel Control : OBD-0 MPFI
D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Ferio Vi
Rod Length : 137 mm
Compression : 9.6:1
Fuel Control : OBD-2 MPFI
Found in:
1992-1995 Civic GTi
Compression : 9.5:1
Valvetrain : DOHC
D15B
VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
As he already said, the D15B will have more aftermarket support then the A9. and you can also probably find a complete D15B swap fairly cheep.
