01 & up Auto to Manual, K20 Swap parts list
For any of you out there like me with an 01 or higher that wish you had more horses under the hood and a manual tranny here are the parts you need for a K20 Swap. I am sure there are a few other little hidden things you need to.
Provided by Hasport http://www.hasport.com http://hasport.com/Tech/Installs/ESK1.htm 1 Complete K20A Changeover (Motor/Trans/ECU/Cat. Converter/Wiring) 1 K20A Intermediate Shaft 1 Axles from 02+ Civic Si 1 RSX or 02+ Civic Si Sub Frame 1 Hasport ESK1 Bolt In Mount Kit 1 Hasport ESKWH Conversion Harness (Available From Hasport Soon) 1 RSX Shifter Assembly & Cables 1 02+ Civic Si Radiator & Fans (RSX Will Fit With Some Trimming Around Cap Opening In Grill) (Condenser Fan Assembly Available From Hasport Part # ESCFA $125) 1 02+ Civic Si Upper & Lower Radiator Hoses 1 RSX Throttle Cable 1 RSX Fuel Line 1 RSX Brake Booster Line 1 RSX Purge Line 1 2002+ Civic Si AC Line From Compressor to Condenser 1 RSX Clutch Lines From Master to Slave Cylinder 1 Custom AC Line from Compressor to Condenser 1 90 Accord Negative Battery cable 1 Custom Hood Latch Support 1 RSX High Pressure Power Steering Hose (If You Want Power Steering) 1 RSX Power Steering Return Line (If You Want Power Steering) 1 92-95 Civic Power Steering Reservoir With Bracket (If You Want Power Steering) For an Automatic to Manual Swap after talking to BlackTrax Performance in Milpitas, CA you will need to obtain the whole clutch pedal assembly and master cylinder and change the brake pedal. The original brake mounting and brake booster will stay. The Hasport parts list says is that you can use a RSX clutch line. BlackTrax said that they had a custom line made. I do not know if they knew the RSX line would work or not. I have looked at so much on the internet lately I cant remember where I saw it but supposedly you can swap some of the RSX suspension parts and axles and run 5 lug wheels. If I find it I will post it. Check out the 2002 Honda Civic/RSX Type S Engine and Auto to Manual Swap that BlackTrax did. http://www.blacktrax.net/project001newZ.html |
RE: 01 & up Auto to Manual, K20 Swap parts list
cool i want it. it probably cost too much!!!!
Thats alot of stuff to buy. sound like a fun swap HaHa
