02 ex hose problem
First off let me say that the image is not of my civic. Anyway, my intake has worn a slit in this hose, my questions would be-
1. What is this hose for? It has oil leaking out but its not leaking very much.
2. I need to replace this hose, does it say a specific part number anywhere on the hose?
3. Since oil is leaking out of the hose, should i drain the oil before changing it?
4. I believe this slit has been worn due to heat, what can I wrap this hose in and to make sure this dosen't happen again?
5. I have found that duct tape can fix just about anything, if i were to wrap this hose in duct tape where the slit is, would it really hurt anything?
Thank you in advance for your help and advice.
