06 civic si power...
Old Sep 16, 2007 | 06:45 PM
psht yea's Avatar
Default 06 civic si power...
[align=left]I have a 06 si with a intake and exuast which I belive is pulling around 220hp.
any ideas on how i can safely get upwards of 300?
thanks
[/align]
Old Sep 16, 2007 | 07:28 PM
warner_ro's Avatar
Default RE: 06 civic si power...
i have an 07 si. i have about 230hp to the motor right now with I/H/E, plus ETD to help agasint wheel hop. you have probably about 215 top to the motor and 185 to the wheels. the SI is 197 to the motor at 7800 rpms. the wheel power is about 15% less then the motor. to get 300 hp safely. get intake manifold, header, cams, pistons, fuel system, throttle body and nitrious. you'll get there that way. or just step up and get a turbo with all that except the header, and intake, cuz those will be replaced with the turbo system.
Old Sep 16, 2007 | 07:29 PM
warner_ro's Avatar
with all those upgrades and a tune you could run a 50-shot of nitrious. thats my next thing i am getting, then the hondata ECU tune so i can get VTEC power at 4500 rpms
Old Sep 16, 2007 | 07:51 PM
Street Sniper's Avatar
FIor nitrous to get there. A tune to get it safe.
Old Sep 17, 2007 | 01:06 PM
psht yea's Avatar
thanks for the help...
[align=left] [/align]
Old Sep 17, 2007 | 03:16 PM
PREKGSR's Avatar
ORIGINAL: warner_ro
im in the process of getting my vtec to engage at 4500 also like on a stock gsr , is there any pros and cons about this? mine's set up for 5800
Old Sep 17, 2007 | 05:00 PM
psht yea's Avatar
i'v heard it causes hesitation in first gear....
and rpm"hang"
Old Sep 18, 2007 | 01:32 PM
jason_guy_yeah's Avatar
The reason for vtec is to switch the power band from low end to top end. In other words, dropping the vtec engagment will result in less torque.
Old Sep 19, 2007 | 05:44 PM
psht yea's Avatar
no it wont reduce your overall torque at all...
you'll pull more between 4500rpm and about 6300rpm
but your total at the peak is the same as it was beforehand.
http://hondata.com/reflash_06_civicsi.html
Old Sep 19, 2007 | 06:22 PM
Marty's Avatar
ITB's a set of cams, and a worked head will get you 240 to 250whp and that 197 rated hp is underrated a little and they are putting around 190 to the wheels.
prodigyskate5
Jan 21, 2009 01:13 PM
XNXIXTXRXOX
Aug 22, 2008 10:11 AM
civic_66
Nov 20, 2006 02:44 PM
Kturner
Sep 25, 2006 08:38 AM
e2k4
Sep 11, 2006 07:10 PM
