2001 CIVIC LX - P0303 After Head Gasket Replacement
Old Apr 2, 2015 | 04:25 AM
bmccue1964's Avatar
Default 2001 CIVIC LX - P0303 After Head Gasket Replacement
Hello! This is my first post to this thread. I didn't locate anything similar to it so here I go...
2001 Honda Civic LX - 5sp manual - 302,000 miles. I replaced the head gasket (myself) at 300,000. Had head checked and milled at machine shop. During HG replacement I removed head and left timing belt in (was replaced not too long before). I marked belt and top cam so I could place belt in same position when reassembling. Anyhow after I got everything all back together I started car. It had a rough idle and started throwing mainly a P0303 (sometimes a P0300 - P0304). I replaced plugs. No improvement. While the car was idling I disconnected coil pack on cylinder #3 - idle did NOT get worse. I replaced coil pack. No improvement. I replaced fuel injector for cylinder #3. No improvement. Car seems to drive just fine as long as I'm not waiting at a light. At idle, idles rough and check engine light eventually comes one. I have tried resetting the ECu each time as well to relearn idle. I have stored the OBDII codes if that will help.
ANy thoughs? Could it be a valve issue in cylinder #3 (I plan to run a compression test)? Possibly bad ring (it was running fine before HG replacement).
PS: I have NOT yet cleaned the IACV. I can't see how that would cause a P0303 though.
Thanks
Brian
jpking17
May 26, 2014 11:31 AM
martinc98
Dec 6, 2013 07:30 AM
dylank
Aug 7, 2013 07:59 AM
Kurt Crosbie
Jan 4, 2012 02:25 PM
lvo civic
Mar 16, 2006 12:43 AM
