2001 honda civic EX 1.7
I have 01 civic ex runs great when cold but once its warm it wont start back up and theres no codes it has over 170k miles timming belt is in great shape new spark plugs ! I havent check fuel pressure not sure what to do next
runs and idles good till it warms up! then it dies it will crank but no start and no codes.
I'd really check on the crank position sensor (and maybe the cam position too). Shouldn't be fuel, cause than you'd be stalling, I'm guessing it has to be spark timing and if a crank position is not read properly the ECU doesn't know which cycle the cylinders are at... so yeah.
its fixed ! I baught a cheep crank sensor worked for a couple days then I checked for codes and there was none so I bought a better quality crank sensor and its fixed . dont buy cheap parts. you get what you pay for!
honestabestransport
Feb 13, 2013 07:59 AM
pp_MR2
May 10, 2007 03:44 PM
