89 idles allover somtymz when cold
Old Jul 1, 2008 | 10:00 PM
branx's Avatar
Member
Default 89 idles allover somtymz when cold
ok i have an 89 crx dx and sometimes when i start it cold it will go to like 2000rpm or whatever it is and then to like 500 and back up to 2000, so up and dwn up n down... until i get on the gas. does anyone kno what this is?
Old Jul 1, 2008 | 10:17 PM
Default RE: 89 idles allover somtymz when cold
Is the check engine warning light ON? If so, check the code blinking on the ECU LED under the carpet and below the dash on the passenger's side.
Also try cleaning the EACV (=IACV) (see forum DIY section).
Old Jul 2, 2008 | 08:44 AM
sboarder97km's Avatar
check your antifreeze levels, mine does that when its low...another idea is to check your tubing from the radiator, mine had a small hole in one of the tubes and had that sameproblem
doggpound
Nov 29, 2016 07:52 PM
VTECivic95
14
Aug 2, 2006 10:36 AM
slottieskim
Apr 25, 2006 07:59 AM
baker
Feb 24, 2006 05:57 PM
redtide265
Apr 27, 2005 09:28 PM
