92 B18A1 into a 90 Si Hatch??
how can i get a 92 B18A1 into a 90 Si Hatch...will the motor run off of the interior harness if not what will i have to do to get it to run?
RE: 92 B18A1 into a 90 Si Hatch??
you will need to use your 90 si engine wiring harness. you need to get ef b-series mounts, 92 integra axles, ef b-series shift linkage, obd0 pr4 ecu
assuming your si still has the engine harness nothing as far as the harness goes. direct plug and play.
thanks
