93 LX getting some beef
just wondering if any of these will give me an preformance, or just better quality. i'm looking to tune my car up a little, get some beef.
- underdrive pulley's - throttle body - intake manifold - hot wires i've just heard people talking about these things, and don't really know what they do, or what kind of preformance i can get out of them. any advice would help. thanks guys. |
RE: 93 LX getting some beef
Underdrive pullys-less rotating mass= better acceleration, maybe not a lot, but a decent upgrade
Throttle body-controls amount of air into the intake manifold, bigger diameter throttle body=more air being taken in=more hp and tq Intake manifold-stock IM can have restricted runners and un-needed bends, bigger and straighter diameter runners=more air flowing more efficiently Hot wires-better spark, not worth the invesment for basic bolt ons you are wanting. Over all, a good throttle body and intake are going to net you the most hp for your money. Look at BBK for the throttle body and for the intake...well....Edlebrok, Skunk, Venom..i personally rock the Skunk 2 with a BBK 62mm throttle body and am happy with it |
Intake manifold and throttle body will yield some of the WORST hp per mod/dollar from what I know. Some well known racers won't even touch the throttle body because the gains are so minimal, even on 600+ whp monstors.
Imo, the best products for the out there right now without turboing your car would be a Z6 head swap, Z6 tranny, thin headgasket, akmee cam + valve train, SMSP header, custom header back exhaust, AEM or Injen CAI (still the best imo), Z6 intake manifold+ throttle body, and a quality tune on a Z6 or equilvalent ECU. Some other good mods wouldbe removing the PCV system, thick DIY ground wires, underdrive pulleys, removal of AC and/or PS, good clutch and light flywheel, light wheels (rota slipstreams rule), GOOD TIRES, even a LSD. Compression could get up to about 10.5:1 depending on headgasket choice, which can probably still run medium grade, but premium would be better; would make power to ~8k rpm, and last a heck of a long time if maintained. Basically, until the bottom end gave out, because all other bases would be covered. Power could get close to 150 at the wheels, maybea bit over that. |
like i said, dont listen to me
ya, i was looking at the bbk throttle body, and i think i might be doing that.
Rofl.
mine is faluty anyways, and it needs to be replaced, what is the point in buying a brand new stock one?
Price. Grab a used 60mm B series TB off ebay or from a junkyard. It'll fit.
^True, i got my 62mm BBK for like $75 or somthing like that off ebay. It was slightly used, cleaned it up and you couldent even tell.
hey Kedawei i saw you said the Z6 intake manifold and a B series tb. I was always told that the Y8 was better than the Z6. This true?
