94hondacivicEX |
12-16-2008 09:31 PM |
94 eg ?s
ok got a 94 civic sohc vtec i messed up the block and i went and bout a d16y something it was non vtec i know that doesnt matter but the head bolts are different so i am going to use steel washers to take up the space is that ok? and i used my z6 oil pump it bolted up the only thing different was the oil bolts but i modified them to fit so the oil pumps are the same right? all the 1.6 single cams are compatible right? i bent valves so i got new ones can i just use the same springs? the motor is all stock just headers and an inntake and rail. so if you have any answers or question it would be a big help to ease the mind so thanks
