95 civic ?s
Hey i have a 95 civic 4 door 1.5L 5 speed what is the best thing and cheapest to do to get power
turbo, best bang for your buck.
without a budget, power goal, or knowing your experience (are you going to install it?) that's all I have for you. Intake/header/exhaust won't gain you much but a nice look and some noise. |
95 civic 4 door
What kind of power can u make from just turboing a d15 and make it a safe daily driver
~180whp without opening the motor up and replacing internals. Quick list off the top of my head that you will need:
turbo manifold waste gate intercooler intercooler piping blow off valve tuning injectors various vacuum hoses wideband o2 sensor (not necessary, but a good idea) gauges (again, not necessary, but a good idea) then start focusing on putting that power to the ground coilovers/suspension tires clutch Spanning across all the honda forums, I'm sure your question has been asked millions of times at this point so the info is out there. There is a stick somewhere on this forum (probably in the turbo section) going over this list. edit: here you go https://www.hondacivicforum.com/foru...ion-faq-68360/ |
