95 si d16z6
[&:] I have a 95 hb civic si. All I have is a cold air intake, and soon ill have a high flow cat, catback exhaust and obx intake manifold. What can I do internally, or externally to my engine that wouldn't cost an extreme amount of money, and would be somewhat easy to do? I was thinking about a obx r cam, and maybe a light flywheel and clutch. Any suggestions? Is it even worth putting money into that engine with 130,000 miles on it? Or should I just go with a b16 swap and saw screw the soch?
RE: 95 si d16z6
a pully would really free up a lot of power, maybe some headers, a hyper ground kit, spark plug wires, fuel rail, etc
RE: 95 si d16z6
run a compression and leak test and if its ok BOOST it.....cheaper than a swap and ull get serous HP
RE: 95 si d16z6
yeah, once again lol if u boost it go t25 they spool perfectly for our d16z6
RE: 95 si d16z6
i would personally suggest the greddy kit. Its not too expensive and ull get lots of power. its like Se7en says "turbo lag is a courtsy head start"
