97 civic lx vtec help
I put a Vtec in my 97 lx,
Im not sure what year the head came from but im thinking its from a 95 The distributor dont fit!!! can i just buy a 95 distributor and switch out the plugs? Also i read that there is a oil injector in the block that i should have took out when doing a mini me swap is this true? |
https://www.hondacivicforum.com/foru...ead.php?t=3683
http://www.jdmuniverse.com/forums/ho...-write-up.html vtec not VTECH unless you seriously do have a phone in your car and looking at the stuff you got in it its entirely possible |
Good thing for the edit option!! Anyway back on topic..
The old head was bad so i got the 95?96? vtec, The distributor is to big,, If i get the right distributor for this head can i re-wire the distributor plug? I have the gray all in one plug [97],, i think i need to wire in the dual plug type [older]. The wire colors are the same it's just the coil has its own 2 wire plug.. |
