98 civic d16y8
ok heres the deal i blew the motor in my crx and im looki9ng at buying this 98 civic... looks good an all but i dont kno anything about the d16y8.. so my question is, is the motor a good one and what kind of specs for hp am i looking at... the guy is wanting $3500 for it it has 145k sounds like he is kinda old but the car is in perfect shape.. im used to working on 92-95 gen cars even my crx has a d15b7 out of a 92 how much diff is there between these year?
Wikipedia is your friend
"D16Y8 - VTEC * Found in o 1996-2000 Honda Civic EX (US) o 1996-2000 Honda Civic SI (Canada Only) o 1996-1997 Honda del Sol Si + Displacement : 1590cc + Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in) + Rod Length : 137 MM + Rod/Stroke : 1.52 + Compression : 9.6:1 + Valvetrain : SOHC 4 valves per cylinder + Power : 127 hp (94.7 kW, 229 ps) @ rpm + Torque : 111 ft·lbf (45.79 kg/m, 145.1 Nm) @ rp + Head Code : P2J + Piston Code : P2P + Redline 6900 rpm + ECU Code : P2P" It's a common motor, really nothing to get excited about (unless built!). 98 Civic EX, stock everything, 145k miles, perfect body (no dents, scratches or anything) is definitely worth at least $3000. I would just make sure that the timing belt/water pump was done. They usually need replacing at 95K or so. What color is the car you are looking at? 5 speed? |
yea its perfect im gunna go look closer at it and drive it around 730ish... its white with 17inch black rimswindows blacked out but has a gay triabol decal on the sides but o well they prolly come off.... doesnt even have exhaust plain civic with rims tail lights and decal idk...ty for the info and it is a 5 speed
i just checked out ur wikipedia also wow... i learn alot of **** in like 5 mins lol
Try and get a few pics while you"re there. Post them up!
wanna supercharge that d16y8? im trying to sell mine, i dont need it nemore i replaced the y8 for b16 type-r
d16y8 is a good all around motor for anything. Daily driver, turbo, build... Lots of parts laying around the internet
would ur superchager work for a d15b7?
