aftermarket crank? sleeves? ideal rods/pistons and headwork????
b18b
going turbo.. I know this sint the turbo threads.... but please bear with me. I have unanswered questions that really dont matter wethere turbo or not. sleeves nesseceary? aftermarkent lightweight crank worth the $?? what is a good brandcombination in rods and pistons?? heard the guides go bad in stock head after so much boost..? thanks! |
RE: aftermarket crank? sleeves? ideal rods/pistons and headwork????
You don't need two threads for the same topic.
Vitara piston/Eagle rod combo is popular and good for about 500hp on a good tune. |
sweet.. well I did it because I might catch someone else's eye that doesnt go to turbo forum
what do you know about stroking, is that functional with turbo |
they dont make vitaras for the b18b, dont use a lightweight crank with a turbocharger there more for high revving all motor cars. yes your stock sleeves will be good up to 350 whp
Oh yea I forgot vitaras only fit d series... CP or SRP probably make some that will fit.
