alcohol/water injection
does it make sence to run alcohol/water injection on a naturally asparated engine such as a D15 or D16 and will it benifit my engine
RE: alcohol/water injection
no
would it make sense after i swap to the LS and run the turbo?
ORIGINAL: thakid would it make sense after i swap to the LS and run the turbo? |
It has advanced enough IMO, it sprays like N2O and like 40 said the only time you need it is when you cant put a intercooler in big enough to cool the massive amounts of air you are pushing through it. That means hotter air intake temps which sucks when tuning and runs a risk of hurting your engine.
