Almost Completed The Motor
Old 04-18-2007, 05:43 PM
Default Almost Completed The Motor
I have almost finished my motor, I still have to put in the camshafts and springs and retainers.. after that I would like to get it dynoed... I would like to be able to get above 160, does anyone think this setup is possible?
- Weisco High Compression Pistons 11:5:1
- Eagle Rods
- Crower Stage 2 Camshafts
- AEM Tuneable Cam Gears
- Crower Titanium Valve Springs and Retainers
- Skunk 2 Intake Manifold
- Skunk 2 62mm Throttle Body
- AEM Fuel Rail
- AEM Fuel Pressure Regulator
- DC Headers - No Cat - Test Pipe - APexi Muffler
- AEM Full Cold Air Intake
- Skunk 2 Short Shifter
- MSD Ignnition
- ACT Stage VI Clutch
- 8 lb FlyWheel
- Unorthodox Racin Pulley
- AC/PS Removed
Old 04-18-2007, 05:49 PM
Default RE: Almost Completed The Motor
if you mean 160 at the wheels i doubt it, probably 140-150 with all that
Old 04-18-2007, 08:22 PM
riceburner700's Avatar
ad some spray, she can handle it no problem
Old 04-18-2007, 08:58 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
are you staying n/a since you have some high compression pistons?
Old 04-18-2007, 10:09 PM
Whats with all the MSD? I thought stock dizzy can handle 400 hp
Old 04-18-2007, 10:11 PM
you certainly put some time, effort AND money into your motor.
schweet.
Old 04-18-2007, 11:22 PM
All good parts except the MSD crap. Put stock igntion back on and you should make around 150-160. I would also consider using an Exedy Stage 1 clutch (that ACT will be STIFF), and a Quaife LSD (some people recommend OBX, even me before, but after reading around a bit I've decided doing it right the first timeis the way to go). Make sure you have a Z6 or Y8 transmission as well (Z6 preferably). Also, what are you using for tuning?
And just fyi, you have only one cam gear, one camshaft, and one header.
kinosh
09-12-2007 07:19 AM
ic892003
02-06-2007 05:44 PM
tiga10
27
10-11-2006 07:42 AM
derk
02-06-2006 08:43 PM
psychocivic
01-30-2006 07:01 AM
Quick Reply: Almost Completed The Motor
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
