ARP Head studs
Old Sep 9, 2006 | 08:15 PM
redridinhood's Avatar
Default ARP Head studs
im going to be putting a JR supercharger on my civic prob just running six lbs of boost do i need the arp head studs or is it not worth it with low boost like this thanks
Old Sep 9, 2006 | 08:46 PM
riceburner700's Avatar
Default RE: ARP Head studs
you dont "need" them but its just cheap insurence
Old Sep 9, 2006 | 09:35 PM
Fiasco's Avatar
with stress on cheap. 100 bucks on ebay for these studs and you can breathe easy.
Old Sep 9, 2006 | 09:57 PM
importcivicus's Avatar
i wouldn't really trust stuff from ebay unless they are marked in a way you can tell that it is by that company. Because anyone can goto a local store and by some studs and sell them on ebay for more than there worth and a couple months doewn the road ur kind of screwed because your engine is now not producing any boost cause you had bought an ebay stud.
Old Sep 9, 2006 | 11:03 PM
finalimpact's Avatar
ive boosted 14psi with a 14b on a stock d16y7 and never had issues with the head lifting. arp are cheap insurance though. im currently a dohc zc with a jrsc at 5.5 psi and have no problems.
Old Sep 10, 2006 | 08:25 AM
pWnEdU's Avatar
I recommend head studs for anyone running boost...
You guys are lucky they're so cheap for your engine. The head studs that I installed in the cummins I had were $450.
Old Sep 10, 2006 | 08:58 AM
Marty's Avatar
you should be ok as long as your head has never been removed(as long as your stock head bolts have not been re-used)
Old Sep 10, 2006 | 09:52 AM
Nail I3unny's Avatar
as long as you're on ebay and they have good feedback you should be able to trust them.
Old Sep 10, 2006 | 11:54 AM
Fiasco's Avatar
this is why they have a feedback system. Guys who do the things you talk about have already been singled out by now.
Old Sep 10, 2006 | 07:22 PM
ok ill prob get the arp head studs because im doin the mini me swap so while its all torn down it sounds worth it to throw em in plus if i decide to up the boost then the motor will be alot safer thanks guys
