HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   b16 head torque specs (https://www.hondacivicforum.com/forum/engine-internal-11/b16-head-torque-specs-17628/)
DJYoshaBYD Feb 25, 2006 02:33 PM
ok.. just got back from luch.. my engine is starting to stumble on startup and there is a liberal amount of oil where the head meets the block by the timing belt... I know I need a new head gasket.. I KNOW!!! lol
but what I dont have are the torque specs for my b16 head.. there is no store around me that carries a book with this motor in it...
does anyone have a book? does anyone know the numbers by heart?
I need:
cam bearing cap torque
Head torque and order of torque (literally out of the book if you can)
I need this info so I can change the head gasket before it REALLY goes....
Nail I3unny Feb 25, 2006 02:43 PM
RE: b16 head torque specs
look for an 99-00 si chilton.
DJYoshaBYD Feb 25, 2006 02:44 PM
I cant find any of those either,,, I dont have time to wait, because I have a 60 mile commute everyday... do you happen to have one?
DJYoshaBYD Feb 25, 2006 03:18 PM
I found em
thanks
Head bolt = 63 ft/lb +/-2
Cam holders = 22 ft/lb +/-2 and the outside 6mm bolts are 8 ft/lb.
Remember to torque it in 3 steps and follow the seguence, it's usually
inside out. If you're using an extension, add a couple more
pounds to it to compensate for torque loss.
