B16a oil question
My car was a quart low of oil and my Engine Check light came on...Shouldn't my oil light have came on?
jump the ecu and pull the code, tell us what it says.
a quart low wouldn't make the light come on. |
Alright will do...maybe tommorrow if i have time ill run to Advance and use their scanner
you can run to autozone or do it yourself, use a paper clip or a small piece of wire and jump the green plug abouve the ecu and turn the key on.
btw i'm still rockin that ps2 thx |
haha...i just think itll be easier using a scanner so i don't have to look up the codes...but will a scanner work with an obd1 engine?
obd2 ecu??? yeah
im pretty sure it is but not completely positive
well just got back from Advance and well i figured out that the scanner couldn't read off my computer...so where can i go from here?
