B18 Engine Swap
Hey guys, I have 5 grand + stock 2000 ex coupe (d16y8 engine 1.6l).
I want to know if any B18 will drop into my car? And or what other "bigger" engines will fit directly into my stock civic. I need to know pretty soon guys, THANKS :) |
RE: B18 Engine Swap
whats up...yes a b18 will fit...i think the h22's will fit also
RE: B18 Engine Swap
any bseries should fit right in, but hope you know that since ur running a dseries motor u also need the tranny, ecu,harnesses axels, etc
RE: B18 Engine Swap
Get a GSR or B18C engine and drop it in there, you could always build it up and turbo it and make very good power.
RE: B18 Engine Swap
tranny, ecu, harnesses axels, and what?
And how much do you guys think ill be spending? |
RE: B18 Engine Swap
ORIGINAL: Redline25 tranny, ecu, harnesses axels, and what? And how much do you guys think ill be spending? also it depends what motor you will be buying before we can give you a price. what engine are you looking at? and what do you plan on doing with the engine in the future after the swap? |
RE: B18 Engine Swap
JDM GSR is $3,000 for the motor, tranny, axles and ECU. You will need motor mounts from an integra and some wire for the swap.
