the best block?
what is the best block to get 200 hp out of a b16a2 head. I wasnt sure if its the b18c1, b18c5 or b18b, i remember someone saying that you can get 200 hp out of a b block with a b16a2 head. i will be doing forced induction as well. thanks for the help
RE: the best block?
b18c5 comes stock with 200hp.
RE: the best block?
any block is capable of 200 hp. the c5 has 195hp stock and is a very good engine, but costs a ton. a gsr would be the way to go 170 stock and more torque than a b16, still expensive. a turbo d could get you at least 200 hp on a stock bottom with a good tune.
RE: the best block?
there is a b series combo with the b16a2 head that gives a good hp with a different block
i just dont know what it is |
RE: the best block?
any b16 head with a b18 or b20 block can make 200 hp is you build it right
RE: the best block?
got a really good point^^^
RE: the best block?
I know of a Block specifically for hondas that put out 270 hp and for 7k
RE: the best block?
im lookin to swap out my b16a2 block and put a better one in for the b16a2 head, this is why im asking
RE: the best block?
ORIGINAL: burnindesirez02 I know of a Block specifically for hondas that put out 270 hp and for 7k |
RE: the best block?
i would go with the CRVtec setup then throw in a set of ARP rod bolts and u can boost it and make more than 200 hp all day
