best build for an allmotor LS?
Me and a friend of mine just got a b18b1 for real cheap and i was wondering whats the best build. We want to do a direct swap, We dont want to deal with modifying the parts to make it fit. Where looking for plug and play hp adders.
Which cams and valves springs? Which cam gears? Which pistons? Which intake manifold? |
RE: best build for an allmotor LS?
Give us a range on your budget?
$1000. I just wanna build it, I dont wanna do a ls/v.
hmm thats not much to play with.
Cams for a B18B non-vtec, I have no idea. Cam gears at this point I dont think you need Pistons, look for some Type-R's Intake mani, there is skunk2 and edelbrock also Ok, Id sped the money on letting that weezing engine breath, intake/intake mani, good headers and then some compression inside. Cams are great too if you can find some for the B18B. There should be some, I just have never looked. |
would p30 pistons work? would that make a differnce?
intake, intake manifold (skunk2 or eddelbrock), HC pistons, header. those are probably the best parts you can get for maximum HP increase within 1000 bucks.
