best cam gears and pulleys for 00' SI
RE: best cam gears and pulleys for 00' SI
Toda cam gears and stock pully's, the only reason for you to swap your pully's is if you can get a set from a civic type r because they are lighter. Do not get aftermarket pully's stick with OE because the things are running everything that keeps your engine going good. You do not need to go under-driving accesories such as the alternator which supplies ample current to your ignition system, ps pump as it will result in dammage, or ac pump as it will not performe good and may lead to dammage.
99silverSI
08-25-2007 09:43 PM
top99sir
01-06-2006 07:43 PM
