BIGGEST ENGINE?
Old Mar 30, 2006 | 02:14 AM
mattallica's Avatar
Default BIGGEST ENGINE?
WHAT IS THE BIGGEST SWAP I CAN DO??? WITHOUT CHANGING MOUNTS?
Old Mar 30, 2006 | 02:47 AM
Marty's Avatar
Default RE: BIGGEST ENGINE?
what car do you have?
Old Mar 30, 2006 | 08:30 PM
outlaw2049's Avatar
lol yeah that type of info usually helps.
Old Mar 30, 2006 | 08:33 PM
Street Sniper's Avatar
I dont' think there is any higher displacement swap you can do without mounts. If I am not mistaken, the B16A will bolt right up to some D series trannys and mounts, but that's not "bigger."
What's with the caps lock?
Old Mar 30, 2006 | 08:41 PM
Kedawei's Avatar
B's have the same mounting points, but you can't bolt a B16 to a D tranny.
Old Mar 30, 2006 | 08:51 PM
Mounts.
Old Mar 30, 2006 | 09:15 PM
MccM's Avatar
what is the advantage of b motors. moddable? weight?
Old Mar 30, 2006 | 09:18 PM
AgentofDarkness's Avatar
B series engines have the best aftermarket i believe. There are a lot of parts you can buy for them, and they have a whole lot of potential. They also make more power and are usually bigger than d series engines.
Old Mar 30, 2006 | 09:31 PM
Kedawei's Avatar
:edit: Better not poke the bull.
Old Mar 30, 2006 | 09:50 PM
ORIGINAL: Kedawei
Is that an inside joke? B/C i dont' understand.
