BLOCK GAURD AND THICKER HEAD GASKET
Old 11-13-2007, 06:20 AM
Default BLOCK GAURD AND THICKER HEAD GASKET
alrit guys,havent resolved wat is wrong with my engine yet, gonna wip the head off probably later this week with a mechanic friend, are block gaurds any good cause i have found this. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300169970366&f romMakeTrack=true
this is the minimum i am goin to need (tha is if it is only the head gasket). thinkin of gettin this and if i find the pistons and rings are damaged i will order some forged items from the us.
thanks.
Old 11-20-2007, 07:18 PM
Default RE: BLOCK GAURD AND THICKER HEAD GASKET
If you havent bought anything yet those Golden Eagle block guards are one of the best, I liked the ARP but they stopped selling them, and these golden eagle ones look the exact same. Some blockguards just have holes and dont allow enough coolent to flow and causes major hotspots which leads to pre-mature headgasket failure. Blockgaurds cheep thick sleeving expensive... That should explain it..
Old 11-21-2007, 08:12 AM
how are hot spots going to cause pre-mature headgasket failure?
the hotspots your thinking of are in the cylinder sleeve and liner, which can crack, and either need to be re-sleeved or a new block sourced.
there is a recommended way to do it when you go about putting a block guard in. the recomended way is to put the block guard in before machine work that way the top of the cylinder bore isnt distored. sure you coud get away with doing it before machining, but i personally (if it was my engine) would put the block guard in before machinging then have it machined then the engine put together
slade8
12-06-2009 06:23 PM
stylincompact
03-13-2008 09:07 AM
tombakers
12-21-2007 03:58 PM
boosted_honda
04-04-2006 07:05 PM
riceburner700
01-21-2006 08:17 PM
Quick Reply: BLOCK GAURD AND THICKER HEAD GASKET
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
