HondaCivicForum.com
-   Engine & Internal (https://www.hondacivicforum.com/forum/engine-internal-11/)
-   -   block guard (https://www.hondacivicforum.com/forum/engine-internal-11/block-guard-15702/)
smokingemcee 01-20-2006 08:11 PM
block guard
If you install a black guard and the rest of your engine's internals are stock can you run more boost then you could if you didn't have one? (considering the engine's fine-tuned)
Kappa22 01-20-2006 09:52 PM
RE: block guard
Yes, to a certain point. It will mostly just increase the stability and reliability of a boosted engine, but again, only to a certain point.
smokingemcee 01-23-2006 07:08 PM
RE: block guard
know how to install one?
Kappa22 01-23-2006 07:29 PM
RE: block guard
Yeah, you have to heat the block and guard up to normal operating temperature, then press it in and hone the cylinders.
Short answer: Take it to a machine shop.
smokingemcee 01-23-2006 07:46 PM
RE: block guard
Yeah, I think I will!
riceburner700 01-23-2006 09:42 PM
RE: block guard
wow i dont have time to do that, probably will just go without one for now:D
97civicturbo 01-24-2006 11:32 PM
RE: block guard
yeah its something that needs to be done when you have the engine apart, definitely not a do it yourself mod.
