block guard
what do you guys think, is it worth putting one in? i have heard mixed thoughts on a block guard. do you think it would be safe to run without one? i am building a b18b turbo for about 400whp.
I know nothing about them personally, so I Google'd it. Seemed pretty easy. Maybe you try dis time :D
http://www.google.com/search?hl=en&b...+it%3F&spell=1 |
Block guards go both ways. I know some people who swear by them, more people I know of are against them though. For 400 whp you might want to consider full sleeves before a block guard as you are starting to get pretty high in the hp numbers for the stock sleeves. A tech at work has a da he built, twin turbo, and he is looking to make 350-400 whp when he is done, and he is block guardless and sleeveless.
U cant go wrong with a block guard it wont hurt a thing how much boost u plan on runnin and stock pistons??
Originally Posted by 209Chris
(Post 751843)
Cooling is also another aspect of the block guard that is highly debated as well. You are effectively making the motor a closed deck and even though the guards are drilled they are still restricting coolant.
Last 3 outta 4 motors I built had em never had an issue that same thermal expansion is what moves the cylinders around on hondas blowen head gaskets and such last engine I built went with a dart racing block those r closed deck motors that once again work fine as far as cooling I realize its all 1 type of alloy as opposed to block guards but ive ran these and havent had any issues at all
