broken bolt help..big pic.
Well..i found a broken bolt today...http://i31.photobucket.com/albums/c3...nginestrip.gif
its in there pretty deep and i have no way of grabbing it or anything should I drill and Tap it or is there any other options? |
RE: broken bolt help..big pic.
try the reverse bits ......they unscrew broken bolts. Should work.
dito..... ya should be able to screw the bolt out....
they will take some time :( |
alright...well thanks for the imput....ill hit up autozone on the way home and pick up some reverse bits...
god...well..i drilled and attmpted to use an easy out...but...the drill wont latch on to the easy out...
im letting it soak in liquid wrench...maybe that will soften it up.... otherwise if its not out tommorow..im gunna drill and retap. |
Try getting a flat head screwdriver that would fit into the hole and tap it with a hammer until you make a good enough groove to unscrew the sucker out.
i dont think that would be a good idea the the motor.... isnt the block and such aluminum....... ya definatly dont want to crack it or knock the threads out....
^ Naw you can do it, I did it when I got the threads of a valve cover bolt stuck in the head of my car.
try an ez out
ORIGINAL: addiction2bass i dont think that would be a good idea the the motor.... isnt the block and such aluminum....... ya definatly dont want to crack it or knock the threads out.... |
