The build phase 1
Ok guys. After pulling the Si out of the shop I noticed a small tapping nois I had from the past has grown VERY loud. Almost as if a hammer is smaking on the top of my block. .
It is either: A: Bad wrist pins B: Rod bearings C: Valve (But deemed not the case) That means the Si is goiing into surgery early. Like... next week early. I will try to document as much as I can. So! I was going to do some bottom end work like a SRP piston/eagle rod setup. But thanks to Marty, he found something better! Check it: A fully pre-built bottom end from Import Builders. B16A block Wiseco Turbo Pistons, coated skirts IB Spec H beam Rods Balanced & Polished Crank All Honda Bearings 2x blueprinted New rear main seal New Type-R oil Pump New Type-R water Pump Diamond Bore and Hone Block guard = one nasty Si with over 300whp potential DAILY. |
RE: The build phase 1
F'ing do it!
New Type-R oil Pump New Type-R water Pump ^ VERY good thing to have. |
You really can't go wrong with that setup man, rock out with cock out
****'s gonna pull hard as hell. Glad you listened to Marty.
How much did the bottom end run you? Im looking at building up my 99 si next summer. You can PM me it if you would prefer. That car is gonna be nasty when finished, cant wait to see it!
It is 2300 shipped. Not a bad price after i looked around.
M.I.N.T.
You bastard:-D That block I would drink vodka out of!
