build up, piece by piece. need some help
Hey, working on 2000 honda civic. pretty new to this and trying to figure out best game plan. all help with be appreciated. swapped out to b18c1, type r head, obx light weight pulleys, i/h/e. Looking to turbo down the road and shooting for a 10psi boost. question is i am doing part by part basically everymonth trying to improve performance and looks. looks r Done now to the fun stuff. can i have some suggestions on what your recommendations r? and which steps to take first. looking now for s2 cams and adjustable cam gears. next month s2 intake manifold, biox 68mm throttle body and spacer. high volume fuel rail. and during the next 2 months doing so saving for hondata and a turbo? sound like good plan? and if so whats a decently price well manufactured turbo to go with? should i get a kit or buy all pieces seperately? thanks for the help...
RE: build up, piece by piece. need some help
depending on what stage cams you get you're gonna want to get it tuned after you get the cams, then tuned again when you get the turbo put on.
so if I were you I would buy the hondata ECU before or with the cams, and get it tuned when you put the cams on. it's gonna be cheaper to buy the turbo parts separate, and you'll be able to customize your setup to exactly how you want it.
you'll find this useful for your turbo plans: https://www.hondacivicforum.com/m_400322/tm.htm and this: https://www.hondacivicforum.com/m_196090/tm.htm |
Thanks for the help, those links helped alot!
