building bottom y8
hey guys just need some assurance. im building my bottom end for turbo..i have vitara pistons and eagle h-beam rods. now what bearings do i need, says color coded where is that and do i need to do anything before i instal the pistons and rods..im not boring and the walls are great.help
RE: building bottom y8
what berrings? I like clevite
While you're in there you should pull out the oil pump and bore the ports to clean up that bottom end oiling issue.
what oil issue. and im using honda bearings
ORIGINAL: stylincompact what oil issue. and im using honda bearings |
ok ill do that anyting else? do i lube the piston rod bolt or just tap it together?
You'll want to take the oil pump out, and bore it's ports so that you get more flow through them. It doesn't take much, a little bit goes a long way.
Are you planning on running a y8 head too? |
yeah i have a y8 head. thats all set
ORIGINAL: stylincompact yeah i have a y8 head. thats all set |
