built block turbo b16 (hp limit)
hi, i was wondering what is a safe everyday daily driverhp limit onmy to bebuilt b16a2 on boost!
engine spec: wiseco forged9:1 pistons 81.5mm eagle h beam rods Golden eagle block gaurd cometic head gasket (standard thickness) arp main studs arp head studs acl race bearings i was thinkin 350 flywheel power is this too much for a daily driver? also has anyone any knowledge o f a best procedure to run it in? |
RE: built block turbo b16 (hp limit)
what kinda boost are u runnin? im runnin 15psi with 470 to the wheels an its my DD....ur set up looks prettty good man id say is goin to be ok as a DD..350 is crazy fast..i know it a hot subject but get it sleeved if ur runin over 12psi for a DD. thats alot stress an pressure on everthin.
i have apr head studs an there workin great. what injectors are u lookin to run? an turbo? |
ORIGINAL: PNK SLP what kinda boost are u runnin? im runnin 15psi with 470 to the wheels an its my DD....ur set up looks prettty good man id say is goin to be ok as a DD..350 is crazy fast..i know it a hot subject but get it sleeved if ur runin over 12psi for a DD. thats alot stress an pressure on everthin. i have apr head studs an there workin great. what injectors are u lookin to run? an turbo? im curious on the timing map, b/c thats ALOT of power with a small amount of boost. |
you got some crazy figures on your ride, i have been boosting with 440 cc injectors uprated pump and crome remap on a t04e turbo.
can stock sleeves really only take 12psi or does it dependon turbo size |
ORIGINAL: PNK SLP what kinda boost are u runnin? im runnin 15psi with 470 to the wheels an its my DD....ur set up looks prettty good man id say is goin to be ok as a DD..350 is crazy fast..i know it a hot subject but get it sleeved if ur runin over 12psi for a DD. thats alot stress an pressure on everthin. i have apr head studs an there workin great. what injectors are u lookin to run? an turbo? |
ook man yeah i just came on this site to b.s my number to act cool, ill post my dyno sheet in a month or two when im hittin over 500 Wheel h.p. have u seen my mod list??? oh an how about u just stop talkin an stop actin like u know everythin.
oh an tombakers i would be ruunin at least 550 or 800cc injectors if ur wantin to get 350whp
I dont wanna see a dyno sheet next year when your making 900whp on 17 psi. I wanna see 470whp on 15 psi. Where are your "mods" listed?
is around the forums somewere id post it here but i dont wanna jack this dudes post
ORIGINAL: tombakers you got some crazy figures on your ride, i have been boosting with 440 cc injectors uprated pump and crome remap on a t04e turbo. can stock sleeves really only take 12psi or does it dependon turbo size |
