Burning Smell at High Speeds
I have a '98 Civic DX that is stock with an AEM SRI and Flowmaster exhaust. I've noticed that when I get going between 60-80 MPH, once I ease off of the gas, there is a rather strong burning smell. It only lasts about five seconds and then it dissipates. I had the whole car looked over about a month ago and my mechanic said there is a slight oil leak where the engine meets the transmission. I guess its not really a "leak," but that area is a bit damp. Could that be causing the smell?
its not your breaks?
My car does that at 100+mph I just ignore it probably not a good thing tho.
the oil leak you speak off is the O" ring around the distributor that goes inside of the head, quick, cheap, easy fix
(Post 689453)
transmission DONT have to come off to replace an oring...lol oull distributor off its the oring around the shaft of the distributor. what does it smell like??
Originally Posted by kanarrjl
(Post 689451)
I think it's maybe burning oil from worn out valve seals. Mine does it too. Does it do it if you let off the gas and cruise at the speed?
(Post 689548)
when i cruise, i smell it.
