cam gears
Old Feb 11, 2006 | 09:33 PM
redrider04's Avatar
Default cam gears
Im getting aem adjustable cam gears for my 04 honda civic dx. what should i adjust the cam to. retard or advance if i want low end speed. what would be the best thing to do
Old Feb 11, 2006 | 09:40 PM
Big T's Avatar
Default RE: cam gears
You want to advance the timing.
Old Feb 11, 2006 | 11:40 PM
fast93civic's Avatar
You can pretty much advace the timing by twisting the distributor towards the fire wall. On the other hand with the cam gear, you have to be very carefull and precise when adjusting. 2-3 degrees is usually fine. But use a light. Dont forget to run premium.
Old Feb 11, 2006 | 11:57 PM
BallardCivic's Avatar
What else do you have installed to make it worth it?
Old Feb 12, 2006 | 07:29 AM
Chimera02EX's Avatar
the distributor
7th gens don't have distributors .
If you don't have anything else installed on that motor, I'd save the money and start with the normal I/H/E. You won't see much from a cam gear on a bone stock motor.
Old Feb 12, 2006 | 10:28 AM
^ I wasnt sure. Far as noticing it on a stock motor, you will. But bolt ons would help.
Old Feb 12, 2006 | 07:30 PM
redrider04's Avatar
aem tru power pulleys, aem v2 intake, greddy cat back exhast, short throw shifter
D17Punk
Nov 9, 2007 11:06 AM
99silverSI
Aug 25, 2007 09:43 PM
SI_smiley07
Aug 10, 2007 02:39 PM
Pete
Oct 13, 2005 11:32 PM
niteryder
Jan 8, 2005 08:49 PM
