cam question
Old Dec 5, 2005 | 01:13 PM
greeksi's Avatar
Default cam question
would it be easier to swap the cams instead of the heads from a k20a2 to k20a3
Old Dec 5, 2005 | 05:46 PM
greeksi's Avatar
Default RE: cam question
instead of doing the whole cylinder head swap
Old Dec 5, 2005 | 06:08 PM
Nail I3unny's Avatar
i think the question is...does it really matter?
but IMO taking the had off one car and putting it on another would be easier. because then you dont have to go through all the trouble of pulling the head apart. you just take out the plugs, undo the bolts, put on the other head, bolt it on, wire it back up.
Old Dec 5, 2005 | 06:11 PM
amg6975's Avatar
Hm, I'd get a head from a k20a?.. integra type-r.
Old Dec 5, 2005 | 06:18 PM
greeksi's Avatar
wich one will give you the most horsepower/torque gains?
Old Dec 5, 2005 | 08:48 PM
BallardCivic's Avatar
A JDM K20a head is probably your best bet for a little extra "oomph."
Old Dec 5, 2005 | 10:44 PM
XCM828's Avatar
Easier, I'd say the cam. Taking off the entire head you have to drain coolant, replace timing belt, and you SHOULD get it resurfaced so it'll seat right. I'm not sure which would give you more power though.
Old Dec 5, 2005 | 11:23 PM
sacicons's Avatar
i havent played with the Ks enough yet, but im thinking they wouldnt fit anyway. the Vtec system itself is different. not 100% though.
Old Dec 5, 2005 | 11:26 PM
Pete's Avatar
personally id just get some comptech cams or something. Theyll give u some sort of gain.
99silverSI
Aug 25, 2007 09:43 PM
dustin_crxsi
Jan 26, 2007 12:59 PM
civicblend97
Apr 29, 2006 01:12 AM
Pete
Oct 13, 2005 11:32 PM
Dickie
Jan 16, 2005 05:56 PM
