cam shafts, valve springs, and retainers
I am going to boost my b16 this spring and wanna throw in some cam shafts and probably springs and retainers. Any suggestions of which to buy? Anybody have any experience with this?
RE: cam shafts, valve springs, and retainers
I hear Crower and Skunk are great.
Agreed
damn that were some rast replys!!! Cool. I was thinking of going with skunk. .
Skunk2 is fantastic. Just make sure you get everything from them, theyll work better in unison because theyre tested with each other.
ORIGINAL: BallardCivic Skunk2 is fantastic. Just make sure you get everything from them, theyll work better in unison because theyre tested with each other. |
on a boosted B its a good idea to get a CTR intake cam and an ITR exhaust cam
Personally id suggest building the bottom end first. Then the top.
ORIGINAL: pcupo12 Personally id suggest building the bottom end first. Then the top. |
it just makes more sence. A built bottom end will allow a helluva lot more boost............the top end wont matter as much. You could run forged rods/pistons ans run 15 psi on a nice tune with the stock head. Build head and stock pistons/rings wont allow anything more really.
