Cams?
aight right now i have single D in my EG but i am going to get a JDM B16A and was wondering what cams i should buy to get some good power gains for N/A, but also i want them to be able to be compatible with F/I cause in the future i want to boost it.
RE: Cams?
depends on the type of fuel controller you plan to run. With a stage 1 you might be able to squeak by with the stock fuel system. A stage 2 will require a fuel controller for sure. Any set of cams will work with boost but for max potential you will need a certain profile cam for the amount of power you plan to put down. Also, cams have alot to do with the RPM you can take them up to. Many show the most significant gains about 7000RPM.
