cams
would puting a set of gsr cams in my b16 make a diffrence or should i just get a part of buddy clubs
RE: cams
I'd reccomend Crower Cams and valve springs/titanium retainers. But it depends on your setup, if you want to run a stage 2 cam or higher you will need the valve springs/retainers.
RE: cams
well im going to be running spray at first 55 shot then going to tune for 75. i want to run cams port and polish,
RE: cams
If your goin N/A you should get a set of Type R cams. If your gunna boost it later, then Id go with the GSR cams.
