can this work with an all motor engine?
http://www.dezod.com/pd_force_fed_co...tnpolished.cfm
I know it says for boosted engines but wouldnt this work for now?
And would I still expaect the same gains?
RE: can this work with an all motor engine?
You'd see gains, but probably not that big of ones. Unless you're running ITB's, an overly aggressive cam, a full valvetrain, and all sorts of other all-motor goodies, the results probably aren't worth it IMO
wow ok. Lets just say I wanted to go with ITB..could you tell me all that that would require for a set up like that and poss how much gain I may see. i can tell its gonna be expensive alreay..
anything this big your gonna run into money being a big part in how big you can go. i dont see just a ported/polished head making 44whp and 60+tq on 6psi. People are getting 200whp out of the d17's on 7-8psi. Even with a professional shop you wont see more than 5-10whp increase with a stock motor and for that price thats rediculious. Now if you have like high compression, good aggressive cam, header, intake/ITB's, exhaust then yeah that port and polish will really pull some good numbers but i wouldnt waste your time on port and polish. I would do a performance 3 angle valve job and you will gain just as much if not more power than the port and polish on a stock head running all motor
Yeah, dude, you need to search. You're just throwing questions out without doing any research.
The Dezod P&P head is for FI, not NA...it'll kill your bottom end power, and not get you a whole lot w/o turbo.
CivicSichick
06-19-2008 10:48 PM
