changing coolant. is this the right place to post?
I am about to change my coolant. 30bucks @ the shoop. I wanna do it bymyself.
http://www.ehow.com/how_1861_change-radiator-fluid.html any advices yall? 50/50 mixture? can i go 100% coolant? will it be better? thank you! |
RE: changing coolant. is this the right place to post?
mix 50/50 or else it wont work up to the recommended colling temperature, but that guide explains it step by step perfectly. if you are gonna do some cooling system cleaner i would recommend BG products because they are the best out there for chemicals that clean
