Civic 97 overheating
Guys I need your help plz, I had overheating problems and it should have been solved as i replaced the radiator and most components in the cooling cycle, now the temp gauge keeps rising till the 3/4 mark and suddenly drops continuously, when i turn on the lights the temp also increases, i changed the thermostat and the heat sensor and the problem is still there. what should i check? the engine is a D16Y5 on a 1997 Civic.
coolant fan relay.
Are you losing coolant? Any noticeably coolant leaks? Have you thoroughly bled the cooling system? Is there white smoke in the exhaust?
Originally Posted by amg
(Post 647260)
..... when i turn on the lights the temp also increases,
Guess I am losing coolant but there are no leaks and there is no white smoke from the exhaust. How shall i test the coolant fan relay?
1 Attachment(s)
Does the radiator fan run when the engine temperature rises above normal? If not, unplug the 2P connector for the radiator fan switch located on the thermostat housing and then connect both terminals of the connector with a jumper wire. The fan should now run continuously. If so, replace the switch.
Next bleed the cooling system: 1) Park the car on an inclined driveway with the front end higher than the rear. 2) Push the dash heater lever/knob to MAX heat. 3) Follow the directions in the diagram below. Skip bleed bolt step as you don't have one. Attachment 19495 |
