trustdestruction |
09-03-2008 12:29 PM |
copied and pasted from Transmission FAQ:
"4. Common Problems
Almost always I read this issue and it is true for just about ANY manual vehicle you will ever own. If you are hearing a dull grinding/sliding sound while in gear your mainshaft bearing is going (aka the ISB or Input Shaft Bearing). This bearing is located on the opposite end of the mainshaft and gets worn quickly because of the clutch pushing it in and out. This bearing also takes the brunt of the torque from your engine. When you replace this bearing it's best to just replace all of the bearings at once, and always use OEM Honda bearings. The install itself is not bad but if you've never pulled apart a transmission I'd suggest against doing it yourself unless you have someone who knows what they're doing to help."
