Compression
If im staying N/A and i put in 8.8:1 compression pistons is that fine? or should i have a higher compression if im staying N/A?
RE: Compression
this is for a d17? 8.8:1 is like turbo pistons, get some 11.5:1 and run high octane.
RE: Compression
8.8 would probably lower than stock and you will loose power, run 11+
RE: Compression
do you know if they make high compression? stock right now is 9.5:1 and i have only found lower but i was planning on getting a new camshaft, a new cam gear, and valve springs and retainers, new valves. I know its going to be a lot of money, its a long term project for me. Is there anything else i can/should upgrade along with that?
