Compression test help
I want to do a compression check on my Ls engine.The engine is not in a vechile can i just turn the crank or flywheeland get the compression pressure with my compression tester?
RE: Compression test help
I did the test.I took out the spark plugs,opened the throttle,put the compression tester on,then I turned the crank pulley with my ratchet.It took me a couple turns to get something on the guage the # were not good.Is there something I did wrong there isnt much oil in it and it wasn't warmed up.Do you think I should still go head with install and test once it gets in car before i see the proper #.
bronxbomerss2
03-20-2012 12:36 PM
