Compression Test, Typical PSI??
Just wondering what is a new motor, and an average 100,000-150,000 mile motor have on a compression test? I just did mine and they were 151 149 150 150
It is a d16z6 |
dont have the specs in front of me, but i think that 170ish is normal for newer honda engines... not completely sure, but i know its close...
does your car have 100-150k miles? if so, thats pretty good that all 4 cyls are that close together.. |
That sounds about as good as it gets. Most important thing is the percentage difference between the individual cylinders. Mine is significantly lower cause of my 7.5:1 or so compression, but the deviation between the cylinders in my new motor are comparable to yours.
________ Mng San Francisco |
I just flipped 135,000. When I tested it and seen how close they were, I had a feeling that it was a good thing. Thanks for the info. I have looked all over and never could find a straight answer.
My 00 SOHC Civic was hitting 190 psi on cylinders 1, 2 & 4 - 3 had 0... from a cracked exhaust valve... BUT the good news is that sounds normal, especially since they are all the same! Very good sign!
