Compressions
Old Apr 13, 2006 | 06:20 PM
US3R!!!11one's Avatar
Default Compressions
Does anyone know, or know a site, where I can check the stock compression on honda motors? Specifically an h22? Thanks in advance.
Old Apr 13, 2006 | 07:43 PM
slvcivic00's Avatar
Default RE: Compressions
Your H22 is probably running between 10.6-11/1 depending on the year of the motor. Oh and hear is the site where I got the info: http://www.hondahookup.com/charts/ho...ison_chart.php
Old Apr 13, 2006 | 09:51 PM
Thanks, but I need to know the actual compression numbers for each chamber, not the compression ratio. I should have been more specific, my bad.
Old Apr 13, 2006 | 09:55 PM
AgentofDarkness's Avatar
If you suspect that you have bad compression, check the compression in all the cylinders and write it down. The compression should be within 10% of each other.
Old Apr 14, 2006 | 01:59 AM
I know that, once again I just need to know the stock compression numbers for an h22.
Old Apr 14, 2006 | 04:18 AM
Marty's Avatar
around 180
Old Apr 14, 2006 | 01:47 PM
Ok thx. Mine are around 220 for some reason =(
Old Apr 14, 2006 | 01:51 PM
Marty's Avatar
What H22 do you have? If it is the H22-S it will be higher
Old Apr 14, 2006 | 03:44 PM
I have a JDM h22, just regular. I had some problems getting a plug out yesterday, but I got all of them today. My compression is:
Leftside - 215 220 250 255 - Rightside
This is really confusing. I also am having air blowing out of the oil cap when I take it off. I have a breather filter on my engine, and I noticed it was all oily which prompted me to check. Apparently something is stopped up somewhere. I checked my PCV valve, and its clean. I really dont know where to start looking.
Old Apr 14, 2006 | 05:23 PM
Marty's Avatar
Are you doing the test with the trottle plate open or closed
