Coolant Flow Problem!
Hi
I have a 95 civic and the coolant in the resovoir tank stays in there and does not go back into the rad when it is needed? whats could it be??? Thx josh |
RE: Coolant Flow Problem!
Have you bleed the system lately?Is the bottom of the jug pluged?
I just did a complete coolant flush, and no the resovoir tank is not clogged at all
josh |
maybe your car just has enough coolant to keep it in proper working temperature, so thatt everytime you check it it seems like nothing is going back in but in fact it is when your driving.... but then again, it could also be an issue... i dunno i am not tech certified. i jsut throw ideas in the air and if they work then good
Hi
I know it doesnt go back into the rad bc its starts to overheat after a few days of driving bc it doesnt go back into the rad. Ant tips?? Josh |
