Crank Pulley Debate
I know there is debate on whether to change your crank pully.I knowan underdivencrank pully isn't good, but what about just a size difference?What are the advantages and disavantages and should I get one?
RE: Crank Pulley Debate
dont even waste your money, i just finaly got mine off because the bolt stuck in tehre and NOTHING would take it off. I didnt even see a difference in power
you can get power gains in more logical ways
Ya, Im not sure what all the hype is about these things, I guess its cause they look nice.
ORIGINAL: Big T I know an underdiven crank pully isn't good, but what about just a size difference? they also weigh a lot less |
and are fine to use if you DO NOT have a harmonic balancer built into your original.
i felt some power gains in mine. not lots but a little. and ya is does look nice, the difference in wieght when i held them both was huge.
If you really want to get rid of your stock pulley just put on a lighter billet aluminum one that's the same size. That will reduce the rotational weight a little and give you a small power gain, but there are better things to invest you money in.
ORIGINAL: Roto and are fine to use if you DO NOT have a harmonic balancer built into your original. |
ORIGINAL: riceburner700 dont even waste your money, i just finaly got mine off because the bolt stuck in tehre and NOTHING would take it off. I didnt even see a difference in power |
